Using Robot Titan in Scene Prevents Creation of New Cameras
Hi,
So I added the Robot Titan to a scene, and just what the title says happened. When attempting to create a camera in the scene, I get an error:
A node labeled "Camera" already exists in the scene.
A node named "Camera" already exists in the scene.
Adjustments have been made. Verify the adjustments and try again.
Trying again results in the same error. I had to search the scene for "camera" to find it was this figure, which has a bone/part labeled camera. Renaming the bone "cam" or anything else does nothing to alter the outcome. Using 4.15.0.2 Pro version. Any suggestions on fixing this or is this a bug that I need to report? The only fix I can find is to add the camera then add the figure.
  • SevrinSevrin Posts: 6,314
    Name the camera something other than "Camera".
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,512
    edited March 2021
    does it give you the fix conflict option?
    do you have show advanced in the camera dialogue?
  • WandererWanderer Posts: 957
    I had to rename both the name and the label as something other than camera. I added numbers to it, but the OCD part of my brain goes bonkers over that one. Where's camera one it keeps asking. Strangely, when I tried to do so when I had the original scene open, I couldn't get it to work even with renaming the camera. Upon returning to the matter and checking by itself in a new scene, it will work if I rename and relabel the camera.
    I do not see a fix conflict option or a show advanced option. It seems to work okay this way, but worth noting that it's an issue for Daz when a part of an object is named camera.
  • NorthOf45NorthOf45 Posts: 5,896
    The camera node on Robot Titan is not recognized as a Camera object by Studio, so it tries to do what it is designed to do, add a Camera. Why it works okay if the Camera is added first, then Robot Titan, I don't know. Could have something to do with hierarchy scanning and node structure. I tried renaming the bone and saving Modified Assets, but the original name comes back. I suppose it also needs a new face group to go with the new bone name, and updating the controllers to match. I'm tired already...
