Are there any Bryce 7 Mac benchmark tests?
Hello friends, after many years i came back to my beloved Bryce. At the moment i use a Imac 27 12.2 with Intel Core i7, 3.4 Ghz with OS 10.6.8.
I would like to speed the Bryce rendering up, so i think about a MacPro alternative, a Apple Mac Pro 5,1 2009 12-Core 3.46GHz. Does it makes
sense, will it increase the render time? Or is it better to work with network render?
Thank you for your comments and thoughts. Joe
    You will not be able to use Bryce on any machine that has a higher OS x  than 10.6.
  • Hello Chohole,
    yes i know that´s why i use 10.6.8 on my Imac - Bryce 7 works fine. I would use the MacPro with 10.6.8 too. But does it makes sense - is it much faster with the 12 cores?
    Yes i know, that´s why i use 10.6.8 on my Imac with Bryce 7, it works fine. The question is if a MacPro with 12 cores would be much faster than the Imac (Both with 10.6.8)?
    edited March 2021
    I am not teccy enough to be able to answer that,  Hopefully one of our Mac users will see this thread.  Richard (Haseltine)  has just said that  there's probably a limit to how many threads a 32 bit application could handle, due to the limits on data management. If the application is multi-threaded then each thread can use a core,  but he is not a Bryce user.
    Post edited by Chohole on
  • Somewhere here i read "Both raytracers use only the CPU but can use several cores. At the time, we were told that it is limited to 8 cores."
    So that is only for PC? The original Bryce was for Mac and PC.
  • HoroHoro Posts: 11,756
    From a PC point of view: yes, Bryce 7.1 can officially use up to 8 CPU cores/threads, though I've seen my i9 CPU using all 16.
    Thanks Horo, it seems its better to switch to PC for Bryce 7.1. I´m an absolute Mac enthusiast and really have no PC experience, any suggestions or tips for a Bryce PC Render Station?
    Intel I9, 16 Cores, how much RAM? Windows 10?
