Facial Expressions Location
I have a few different expressions installed, they appear all over the place.
Body/Pose Controls/Head/Expressions/folder
Head/Pose Controls/Head/Expressions/folder
Head/folder
Is there a way to relocate them to one central location?
It would be nice if it was more standardised.
I move folders around all the time in the content library, in order to make more sense, particularly re-colours.
  • Richard HaseltineRichard Haseltine Posts: 111,296
    The location is stored as the Path in the Parameetr Settings dialogue, which you can open from the gear icon on the slider - make sure that the type is set to Modifier/Pose too. I would save the result as a Scene Subset, aving the modified assets back will not work if you installed via Daz Connect (within Daz Studio), and will be overwritten if the product is updated.
  • mmoch25mmoch25 Posts: 145
    Thanks for that, I'm grasping at straws here, but is there a way to batch relocate them?
    edited March 2021
    Right-click in the Parameters pane and set it to Edit mode, you can then multi-select sliders, right-click>Set>Property Group...
    Thankyou.
