Export animation to PNG each frame
Derz.OthDerz.Oth Posts: 0
Hello and thnak you for any possible help.
I would like to know if there's a way to export each animation's frame as a png or to pause an animation and export a specific movement on my own???
I want to do that with this http://www.daz3d.com/animate-at-the-park-aniblocks-for-m4
I want in other words a player before shooting, while he runs ans shoots. BUT in png formats so to make an animation cartoon timeline.
Thank you for any possible help - I would be most thankful!!!!!
  • kaotkblisskaotkbliss Posts: 2,918
    Yep, it's very simple :)
    In the render tab under the "Render to" section
    Select "Image Series" from the dropdown
    Enter your start frame and end frame (usually 0 through whatever number your last frame is)
    Enter a name for your images (it will add an index number to the end of whatever filename you choose)
    right beside that, select .PNG as your output type
  • Derz.OthDerz.Oth Posts: 0
    Thank you very much for your support! Much appreciated as it was indeed very easy! :))) Thank you!
    Can I ask also, if it happens to know where I can find an animation with Goalkeeper (European football)?? Just to block the shooter's ball. Ig you know.. :)))
    Thank you!
