LILITH DOESNT WORK IN POSER PRO 2014
ISIKOLISIKOL Posts: 386
FOR GOD SHAKE PEOPLE....PLEASE MAKE THIS THING WORK!!!!
I BOUGHT THE PRO BUNDLE AND I NEED IT FOR COMMERCIAL WORK!!!!!
NOTHING WORKS!!!! NOTHING!!!! THE MERIDIANA CHARACTER DOESNT WORK....NOR THE LILITH MORPH!!!!
IM SO PISSED OF I D BETTER STOP....
ISNT VERSION 1.1.3.50_ THE LATEST ONE FOR POSER?
DO I HAVE TO INSTALL SOMETHING ELSE????
OLYMPIA PLAYS FINE BY THE WAY!!!!!
W H Y T H E H E L L I S S O DIFFICULT FOR L I L I T H TO PLAY?????
  • RawArtRawArt Posts: 6,216
    What is not working?
    Lilith is just a morph so if G2f works in poser (which it does, I know i can use it), then the morph should not be an issue.
    But hard to answer anything without knowing what the specific problem is.
  • ISIKOLISIKOL Posts: 386
    I dont know man...im so dissapointed....i know its just a morph....but its not playing....kori and olympia play fine....Lilith not....i did the install correctly....im so mad right now...you cant imagine....
    do you have a skype account where i can show you live?
    jesus....do i have to change the importer preferences to the directory i have install everything through the scripts?
    In the Properties tab do you have include scales, follow origins and match end points checked?
    There's another thread about Mei Lin not work either.
    Do you have another G2 model with more radical scaling then Olympia or Gia such as Giselle that you know worked before you applied the latest SR?
    I keep getting Air issues slow downs with the new SR as well as some preview oddities.
    I'm seriously considering rolling back to SR4. Are you using Pro 2014 or Game Dev?
  • LeanaLeana Posts: 13,502
    Do you at least see Lilith in the morph list? If not, check that the data files for Lilith are in the right place (as in, with the ones for your other G2F shapes)
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    Here is what I get.
    Poser 2014 SR5, DSON Importer for Poser 1.1.3.50, Lilith HD No changes to the preferences in either Poser or DSON Importer for Poser, except for render preferences, to include not increasing the Sub-D so I am not seeing HD in this render.
    It sounds like it could be an install issue as the files themselves work.
    1000 x 1300 - 65K
  • pearbearpearbear Posts: 227
    Just chiming in because I had a similar problem with Poser and another new figure (Mei Lin).
    That figure worked perfectly after updating to Poser Service Release 5. This is a very new service release that only came out less than two weeks ago.
    To make things extra confusing, when I clicked the "Check Now" for software updates in Poser, a dialog popped up telling me that my software was fully updated, even though I was only running SR 4. It was only thanks to icprncss pointing out to me that there is in fact a SR 5 that I knew I needed an update.
  • nightwolf1982nightwolf1982 Posts: 1,321
    It definitely sounds like the importer isn't loading the morph.
    Can you post the DSON Log file? Find it by going to Scripts > DSON Support > Importer Preferences
    edited October 2014
    thank you all for your help....i wish i could post the log file....i cant do that....i fixed the morph problem....but when it loads the file that i saved its crushing while its trying to conform the boots to the character....
    i even installed the latest sr from sm (5) thanks @icprncss for this
    below are the latest log entries....
    DSONPoser Starting Τετ 29. Οκτ 08:40:26 2014
    creating Scene
    deleting Scene
    creating Scene
    deleting objects
    Importing DSON Data...
    Setup
    DSONPoser Starting Τετ 29. Οκτ 08:41:29 2014
    creating Scene
    deleting Scene
    creating Scene
    deleting objects
    Setup
    DSONPoser Starting Τετ 29. Οκτ 08:43:19 2014
    creating Scene
    Setup
    DSONPoser Starting Τετ 29. Οκτ 08:45:36 2014
    creating Scene
    deleting Scene
    creating Scene
    deleting objects
    Setup
    here is the video
    http://1drv.ms/1tK2aow
    Post edited by ISIKOL on
    A successful DSON load should generate a log file similar to this for each item loaded through the importer:
    DSONPoser Starting Wed Oct 29 03:52:01 2014
    creating Scene
    DSON Importer
    Setup
    DSON Write Path: C:/Users/*********/Documents/Poser Pro 2014 Content/Runtime/DSON/auto_adapted
    Parsing DSON File...
    File Path: C:/Users/*********/Documents/DAZ 3D/Studio/My Library/Runtime/libraries/Character/DAZ People/Lilith 6.duf
    Scanning for dynamic assets...
    Writing character file...
    Loading CR2 File
    Applying settings to actors...
    Loaded file: Lilith 6.duf
    Importer Setup in 0 min 0.0 sec.
    DSON File Read in 0 min 0.2 sec.
    DSON Dynamic Read in 0 min 5.8 sec.
    Poser Native File Created in 0 min 3.6 sec.
    Poser Native File Loaded in 0 min 36.1 sec.
    Applied Settings in 1 min 51.5 sec.
    Total File Load in 2 min 38.9 sec.
    Done
    Is your log showing any of this information?
    At this point from your video it looks like there might be a problem with the file you saved. Have you tried just loading a fresh Lilith 6?
    Hello Nightwolf....whats the point to do it...i mean i spent half an hour load everything and pose her at my liking....if i save the file and that will happen again i will punch my monitor...
    My workflow doesnt allow such a waist of time if you know what i mean...
    I dont know if that has to do anything with the fact that im saving my files using the compression....
    But the fact remain that the whole daon thing is too meshy, too hard for an average user to use....
    I understand your frustration completely. My suggestion was more about testing whether DSON is correctly importing G2F with Lilith. If it is importing correctly, then the problem may be with the file you saved.
    The problem is there just isn't enough info about the specific issue you're having. If you can import other G2F characters correctly, this one should work too. That's why I suggested looking at the log file, it should be showing any errors that might be causing problems.
    Are you using the latest version of the DSON?
    Are you certain this is not an out of memory crash? The DSON begins to create the scene then everything just stops.
    Is it just Lilith you are having issues with? Can you duplicate this issue with another G2F figure and morph such as V6?
    Which version of the library are you using? The internal library uses Flash, the external uses Air. Recent updates of Air have been causing problems for some Poser users.
    What other apps are running on the desktop when you are creating this scene in Poser?
    Here is what I get.
    she looks on the stocky side there. should there be a scale parameter maybe?
  • edited November 2014
    I Know how you feel had problems myself in past with issues like this. you may need to scrap your saved work and start again trying each step/file and see what causing the crash
    Another way to go about this and this will work on others as well. do a manual install by changing the install directory to a new folder somewhere eg. desktop, user download folder etc. so you can see all the files and locations and manually add them.
    the daz install file doesn't show up for me in poser I have to use the poser install file, whether that's a error bug, or just me idk.
    Hope this helps
    Post edited by pwoods52_9a81dbd368 on
