Crotch reduction on Weightlifting Suit
Hiya,
I have this item: https://www.daz3d.com/mec4d-weightlifting-suit-for-genesis-2-male-s
and there doesn't seem to be a way to reduce the crotch size via parameters. I want to be able use this suit on younger characters without such a pronounced bulge.
I have seen this suit (?) worn by a young character here: https://www.daz3d.com/amazing-skins-for-brodie-6 (see second thumbnail image), so it appears it can be done.
Any ideas how this was done?
  • marblemarble Posts: 7,500
    edited March 2021
    solis said:
    Hiya,
    Looks to me like the area was painted out in post for the Brodie images. I can only think that you would have to create a morph. I do that all the time for the opposite reason in that most of the male pants are designed to fit post-surgery males. A few products have a bulge that can be dialled-in but many don't.
    Post edited by marble on
  • Lee MoonLee Moon Posts: 928
    Can you turn limits off on the character's bulge morph and dial a negative amount in?  The wrestling suit bulge will likely reduce that way.  Not sure if there would be any unwanted distortions in either the character or the outfit.
    Perhaps worth a try?
    Lee
  • solissolis Posts: 124
    Hey, thanks for those possible reasons. Had already tried limits-off, negative-dial, and although it helps it still leaves an area of distortion frown
  • margravemargrave Posts: 1,822
    There's Fit Control:https://www.daz3d.com/fit-control-for-genesis-and-genesis-2-male-s That should do what you want, though if you don't have a lot of G2 clothing it probably won't be worth the price tag. In that case, you could always try fixing it with Mesh Grabber, with a weight-mapped Push Modifier with a negative value, or with a smoothing modifier cranked up so it sticks to the base mesh.
    margrave, many thanks for those further suggestions. Will look into them smiley
    I do have Fit Control for the later generations - maybe I'll get it for G2 too - and I know it's a great tool for this sort of thing.
