Scene file not loading - Error Opening File - PLEASE HELP!
mdlark1966mdlark1966 Posts: 108
Hello -
I'm having an issue with a scene that will not load. I have been working with this scene for the last week or so, and have had no problems. Today I tried to do a quick render of part of the scene, and the render hung - took over an hour (usually takes less than a minute) and never did render. I tried to close it out and save the file, but got a failed to save file message. I closed DAZ, re-opened, and tried to open the scene, but now I get a message that says "Error opening file - An error occured while reading the file, see log file for more details."
I'm no expert with log files, so I'm not sure what it's telling me, and I hope that one of you can help me to solve this. I absolutely need this file for my job, and I am under a deadline and don't have time to rebuild the entire scene from scratch again.
Tried to attach the log file as a .txt file, but it would allow me to attach. I've pasted below the bits that seem relevant.
Any help would be GREATLY appreciated - thank you!
+++++++++++++++ DAZ Studio 4.5.1.56 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.3
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: AuthenticAMD
CPU Brand String: AMD Phenom(tm) II X4 965 Processor
Cache Line Size = 64
L2 Associativity = 8
Cache Size = 512
Stepping ID = 3
Model = 4
Family = 15
Extended family = 1
CLFLUSH cache line size = 64
APIC Physical ID = 1
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Hyper-threading Technology
Physical Memory:
Total: 7.2 GB (7783817216)
Avail: 232.6 MB (243908608)
WARNING: fileoutput\dzassetoutfile.cpp(7958): No geometries match the vertex count of morph "FHMA4Realistic_head"
WARNING: fileoutput\dzassetoutfile.cpp(7958): No geometries match the vertex count of morph "FHMA4RealisticClassic_head"
WARNING: fileoutput\dzassetoutfile.cpp(7958): No geometries match the vertex count of morph "FHMA4Stylized_head"
WARNING: fileoutput\dzassetoutfile.cpp(7958): No geometries match the vertex count of morph "FHMG4TheGirlHEAD_head"
Saved image: E:\DAZ 3D\Studio3\Content\Runtime\libraries\My Models\Lazarus 13\Poker Table.duf.png
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795884933120)
Current Memory Usage: 96%
Current DateTime:
Loc: Sun Oct 26 14:45:35 2014
UTC: Sun Oct 26 19:45:35 2014
Temp Data:
Location = C:/Users/Owner/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 223.4 GB (239949836288)
Disk Avail: 60.6 GB (65157812224)
Locale: en_US
No translator found.
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Highway.style
Creating managers
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LAMH/LAMH.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
WARNING: dzvalentinaobjectdatabase.cpp(36): DB Register Open error: Stream read error.
Using GLEW 1.7.0
Supported OpenGL extensions:
GL_AMD_multi_draw_indirect
GL_ARB_arrays_of_arrays : NOT INITIALIZED
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_buffer_storage : NOT INITIALIZED
GL_ARB_clear_buffer_object : NOT INITIALIZED
GL_ARB_clear_texture : NOT INITIALIZED
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_compute_shader : NOT INITIALIZED
GL_ARB_compute_variable_group_size : NOT INITIALIZED
GL_ARB_copy_buffer
GL_ARB_copy_image : NOT INITIALIZED
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts : NOT INITIALIZED
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility : NOT INITIALIZED
GL_ARB_ES3_1_compatibility : NOT INITIALIZED
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location : NOT INITIALIZED
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport : NOT INITIALIZED
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments : NOT INITIALIZED
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_indirect_parameters : NOT INITIALIZED
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2 : NOT INITIALIZED
GL_ARB_invalidate_subdata : NOT INITIALIZED
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind : NOT INITIALIZED
GL_ARB_multi_draw_indirect : NOT INITIALIZED
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query : NOT INITIALIZED
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior : NOT INITIALIZED
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_draw_parameters : NOT INITIALIZED
GL_ARB_shader_group_vote : NOT INITIALIZED
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size : NOT INITIALIZED
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_query_buffer_object : NOT INITIALIZED
GL_ARB_shader_storage_buffer_object : NOT INITIALIZED
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_sparse_texture : NOT INITIALIZED
GL_ARB_stencil_texturing : NOT INITIALIZED
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range : NOT INITIALIZED
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge : NOT INITIALIZED
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels : NOT INITIALIZED
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8 : NOT INITIALIZED
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample : NOT INITIALIZED
GL_ARB_texture_swizzle
GL_ARB_texture_view : NOT INITIALIZED
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding : NOT INITIALIZED
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev : NOT INITIALIZED
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_S3_s3tc
GL_EXT_texture_env_add
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shader_integer_mix : NOT INITIALIZED
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod : NOT INITIALIZED
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_storage : NOT INITIALIZED
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2 : NOT INITIALIZED
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_import_sync_object : NOT INITIALIZED
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug : NOT INITIALIZED
GL_KTX_buffer_region
GL_NV_bindless_multi_draw_indirect : NOT INITIALIZED
GL_NV_bindless_multi_draw_indirect_count : NOT INITIALIZED
GL_NV_blend_equation_advanced : NOT INITIALIZED
GL_NV_blend_square
GL_NV_compute_program5 : NOT INITIALIZED
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture : NOT INITIALIZED
GL_NV_ES1_1_compatibility : NOT INITIALIZED
GL_NV_ES3_1_compatibility : NOT INITIALIZED
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program_option
GL_NV_fragment_program2
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_gpu_program4_1 : NOT INITIALIZED
GL_NV_gpu_program5
GL_NV_gpu_program5_mem_extended : NOT INITIALIZED
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float : NOT INITIALIZED
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_atomic_counters : NOT INITIALIZED
GL_NV_shader_atomic_float : NOT INITIALIZED
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object : NOT INITIALIZED
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NVX_conditional_render : NOT INITIALIZED
GL_NVX_gpu_memory_info
GL_NV_shader_thread_group : NOT INITIALIZED
GL_KHR_blend_equation_advanced : NOT INITIALIZED
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_ARB_render_texture
WGL_ATI_pixel_format_float
WGL_EXT_create_context_es_profile
WGL_EXT_create_context_es2_profile
WGL_EXT_extensions_string
WGL_EXT_framebuffer_sRGB
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control_tear
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_delay_before_swap
WGL_NV_float_buffer
WGL_NV_multisample_coverage
WGL_NV_render_depth_texture
WGL_NV_render_texture_rectangle
: NOT INITIALIZED
OpenGL features for current hardware:
OpenGL provider: NVIDIA Corporation
OpenGL renderer: GeForce GT 610/PCIe/SSE2
OpenGL version: 4.4.0
Maximum number of lights: 8
Number of auxiliary buffers: 4
Number of texture units: 4
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: Best Performance
RGBA color bitplane resolutions: 8 8 8 0
GLSL version: 4.40 NVIDIA via Cg compiler
Shadow mapping supported
VBO supported
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
d3dGenX.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggercontrol.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothcontrol.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
lamhPlugin.64.dll
sdk_sceneinfopane.dll
dzpowerpose.dll
dzpowerpose.dll
WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
Total class factories: 1230
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
WARNING: QFile::flush: No file engine. Is IODevice open?
WARNING: QLayout: Cannot add null widget to QGridLayout/
Invalid index passed to ActionMgr getCustomAction
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
Json Parser (7476380,28): Unexpected end of file in object.
Error reading file, see log for more details.
WARNING: Object::disconnect: Unexpected null parameter
DEBUG: End DAZ Studio to Hexagon Bridge log...
--------------- DAZ Studio 4.5.1.56 exited ------------------
  • Richard HaseltineRichard Haseltine Posts: 111,721
    Make a copy of the file and then try right-clicking on the file in Explorer and from the menu choose Restore Previous versions - if you are lucky you will have a recent recoverable copy and it will work. If not could you upload the .duf file and perhaps it will be salvageable, though I can't guarantee that.
    If you save when an application has had problems it's always wise to use a new name, so you don't overwrite the existing version.
  • mdlark1966mdlark1966 Posts: 108
    Thanks for the reply Richard. Unfortunately there wasn't a previous version available. I'd gladly upload it to you, but it's a BIG scene - 60 mb zipped. How can I upload it to you?
  • Cayman StudiosCayman Studios Posts: 1,145
    I'm not going to pretend that I know what is happening here or that I understand the log file, but there are a few things that might be worth looking at or trying.
    A few lines down in the log file it says you have available 232.6 MB left of 7.2 GB of physical memory. That is 96% memory usage. See if you can bring that figure down by closing as many other programs as you can, and just running DAZ.
    You might also try making a copy of the original file and trying to open that. Or you could try opening DAZ and then attempt to merge with the file. Another trick might be to try to work out which one or two elements within the file might be taking up the most memory, because they are big or complicated, and then prior to opening the file, uninstall them. This would mean that the file may load but with missing elements. You could then break the file down into separate sub-scenes. Then you could re-install the missing elements and attempt to reconstruct the scene that way.
    But 8 GB of RAM is not really enough to run DAZ Studio nowadays. If you buy some more RAM (say another 8 GB) and put it in your motherboard the file will probably open OK.
    I don't think it normally uses that much ram - I suspect that may have just been part of the computer straining to open that scene.
    I've tried opeining a copy, and merging it, both to no avail. I've got all the different figures and other elements saved seperately, and they are all opening fine. I think something just got corrupted somehow in that scene file and I'm screwed. I don't really have the time to explore exactly which piece of the file is messed up. Since I have all the separate elements it's easier to just start over and re-pose the figures. Not idea. but what can you do?
  • srieschsriesch Posts: 4,243
    This won't help you now, but advice for the future: Periodically save a copy of your work so you have several points to fall back to when something goes wrong. Occasionally I find I've accidentally messed something up; deleted, moved, resized an item, changed a light, applied a material to the wrong object, etc. and I don't notice right away because the change is subtle or I'm working with spot renders and you only see the change in the final render days later. I may still loose some work if I have to fall back to an earlier version, but at least I won't loose it all, and I may even be able to open the older scene and retrieve whatever data I need (such as positioning info, or even saving a piece of the old, good scene as a subset and then merging it with the latest scene to replace a bad piece.
    As I said, I've been working with this file for about a week, and I have the habit of saving every time I make a change. I have no idea why there are no previous versions for me to work with. It's pretty frustrating, to be honest.
    Sean was suggesting saving under a new name - so save 00 initial set up, 01 added G2F, 02 hair and clothes for G2F and so on. I'm a bad about doing that with scenes, but I do it with images and models fairly reliably.
    60MB is pretty large, but you might be able to share it via DropBox or the like. However, I wouldn't hold out great hope of its being recoverable - I've seen several cases where the compression routine seemed to throw an error (in writing data for an external plug-in, though not always the same one) and so DS can't read the end of the file and complains that it isn't properly formatted. If you did haev compression on (which it is by default) it may be worth trying some kind of archive-repair tool, though I've no idea what is good; you coul;d even try expanding the .duf file with a dedicated archive tool (WinZip. WinRar, 7Zip or whatever).
    Ah, I follow you. I've been a full-time graphic artist for over 20 years - regular saves are second-nature to me, but saving with new names is a habit I should probably get into when it comes to stuff like this.
    I honestly have no idea if this is recoverable at all. The log file is less than helpful - I can't find any clues as to what the problem might be.
    Live and learn!
