SOLVED ?? How do I turn a plane into a shadow catcher for the ground ??
DiomedeDiomede Posts: 15,467
edited March 2021 in The Commons
How do I turn a plane into a shadow catcher for the ground?
I have a simple scene with one Daz figure and a tree prop.  I have a landscape spherical HDR representing a clearing in a forest.  My tree prop appears to be floating above the ground.  In other programs I would insert a simple plane and apply a shadow catcher shader.  Is there a way to do that in Daz Studio?  If so, what is it?
Post edited by Diomede on
  • Richard HaseltineRichard Haseltine Posts: 111,842
    Yes - select the plane, then in the Content Library go to Daz Studio Formats.[content directory]>Scipts>Utilities>Create Advanced Iray Node Proeprties  In the Parametrs pane tuern on Enable Iray Matte
  • DiomedeDiomede Posts: 15,467
    Thank you.  Would not have discovered that on my own
  • Seven193Seven193 Posts: 1,156
    I find this video helpful:
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,733
    edited March 2021
    you can also manually move the iray environment groundplane too,
    by default it sits at the base of the lowest thing in the scene
    I seem to recall that method with the Iray node never worked. Maybe it worked with an old version but not newer ones or something. Though things may have changed recently. I always go for the Canvas route. Or you can Draw Ground in the Render Settings and not need a ground plane object.
    Thank you Seven193, Wendy, and ebergerly for the extra info.
