How to use Alatariel? (SOLVED)
reserv888reserv888 Posts: 1,164
edited October 2014 in New Users
A month ago I bought Alatariel and thought of creating scene with it today, but I don't understand how to use it. There seem to be no materials/shaders/textures (I don't know the difference between these three) availabe.
I had the same problem with "The Gallery". That item is at least white in the promos, but this one is not.
What am I supposed to do to make it look like in the promo?
Post edited by reserv888 on
  • Richard HaseltineRichard Haseltine Posts: 111,390
    It should load with its textures already applied. You are loading the prop file, not just importing the OBJ?
  • reserv888reserv888 Posts: 1,164
    I load it the same way as I always do. In this case it is the items from the right column I have used, but it looks the same regardless of what column I use (P4, P5 or PP). See attached pic.
    To be sure, I have test rendered them all and they are still just white.
    1422 x 960 - 1M
    You can clearly see the textures applied on your viewport image?
    I haven't loaded this for years, and it worked first time, no matter if I use the P4, P5 or PP version, although I normally use the PP one.
    You could try resetting your render options to default.
    Ok... So if I understand you correctly you are saying the brown-red color is from lighting, not the item?
    350 x 455 - 58K
    1000 x 1000 - 489K
  • XoechZXoechZ Posts: 1,102
    I do not own that prop, but as far as I can tell from the promo image, the creator has used an orange light to create a mood of sunset. You can see that the leaves at the wall are also tinted orange. So yes, it comes from lightning.
    Here's a quick render I did reserv888.
    The Scene has one Distant Light, and one Spotlight with a brownish/red colour as XoechZ has suggested. You will need to control the Spread Angle and the Intensity in the Parameters pane.
    651 x 670 - 181K
    Ok, got it.
    Thanks alot Richard, XoechZ and Jimmy C for your help. It is much appreciated.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,520
    You can always add an orange tinge to the diffuse channel as well as the textures if you find it too bland.
    I do this with many props, tint them with colour.
