Sudden Menu Configuration Changes
Anyone know why suddenly the configuration of my menus and windows on startup would have changed? Minding my own business, then today I start D|S and suddenly the main menus have changed, no Scripts menu, an undocked set of panes I used to have are gone, the existing main menu subitems have changed, and the default "Dimension preset" in the Render Settings has changed (dimensions of the rendered image). I never did an F3 to change anything, it just happened. But it's the same "startup.duf" file I've always had.
Anyone know what's going on?
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,949
    That sounds as if the layout files were corrupted somehow - one risk factor is force-quitting DS from Task Manager. Reloading the layout (if you saved it) or restoring the layout-related .dsx files in
    %AppData%/daz 3d/studio4/
    from a  back up should get it back.
    Okay, so I looked around and reloaded the "layout" I had been using (F4), and it's back to the last saved layout config. Unfortunately I didn't save/update that layout in recent years, so I have to re-configure it quite a bit. I had forgotten all about the layout customization stuff.
    So I guess the question is, why isn't the layout saved as part of your startup file? Is it in a separate file somewhere? Maybe mine got lost or corrupted?
    The session layout is saved in a set of files in %AppData%/daz 3d/studio4/ - it isn't stored in the scene file or everytime you loaded a scene the layout would potentially reorganise itself. You could, I think, use a script loaded at start up to tell DS to load a specific layout (but then you would lose any chnages made in the rpeviouss ession), though I can't recall the steps.
