(Solved) Can we make JCMs for Pose Control dials?
TamunaTamuna Posts: 82
I've created a piece of clothing for G8F and added a whole bunch of JCMs for necessary joints/bones. But when it comes to the sliders under the Pose Controls sub menu (in the Parameters Tab), I can make a morph to fix the dress, but don't know if there's a way to trigger them automatically, when the relevant Pose Controls dial is used. Those are not inherited by the dress when I transfer the rig transfer as far as I can see. The only thing I can think of is to make visible adjustment morphs that users can set manually when needed. Easy enough to do.
But just in case I thought I'd ask if there was another way to do this, for these morphs to work as other JCMs - automatically. Any advice is appreciated.
Post edited by Tamuna on
  • lilweeplilweep Posts: 2,864
    Morphs can control other morphs.  You can create master/slave relationships between different parameters via ERC.
    In Daz terms, master is the "Controller" and slave is the "Sub-component".  So you would have the Pose Control dial set up as Controller and your morph as Sub-component.
    I can't remember how to set them up.  I think you can just drag and drop the relevant morph into the Controller or otherwise Subcomponent slots in the Property Heirarchy.
  • TamunaTamuna Posts: 82
    Thank you, I've done some searching about Controllers and Sub-Components and found some instructions. A tad outdated, but I think I've figured it out. Cheers!
