WASD suddenly fail to work in view port and my orbit key reassigned to a button I never assigned
Just what is going on all of sudden? I never customized workplace in the last few month and suddenly all of the keys are either stopped working or automatically assigned to a button i never assigned before
  • Richard HaseltineRichard Haseltine Posts: 111,407
    If you are using the defaults try WIndow>Workspace>Select Layout (which will restore the entire UI). You could also try restoring a backup of the layout related .dsx files in
    %AppData%/daz 3d/Studuo4/
    if you have one and want to keep some customisations.
    Be sure to save (f4, Windows>Workspace>Save Layout as) if you're using a custom layout so you don't lose your setup.
    Also, Try pressing the "Preview" button(then cancel), as opposed to the "Accept" button, this often resets the UI non-destructively.
  • windli3356windli3356 Posts: 297
    Ok, that does solve the problem, but why does my Daz randomly disable my WASD like that? sometimes it mess up the content sorting when I never even touched workplace setting, and then it restore to normal after a few days.  Does connect my workplace online cause that?
    Never got a chance to save my last one tho, but thanks, learn something new everyday
    No, connecting wouldn't affect those. It's possible that something is interfering with the saving of the session layout - though on WASD, are you trying shift K to turn it back on in case it's just been turned off by hitting the wrong key (or a cat typing for you)?
