Changing backgrounds with own made textures
aqua1955aqua1955 Posts: 20
edited March 2021 in Daz Studio Discussion
I use to make textures with use of Cyclorama and change them in Poser in the material room.
Been looking how I can change them in Daz3D studio, but can't find the way. See all textures but not my own made.
Can somebody help with this?
Thank you for watching
Post edited by aqua1955 on
  • Richard HaseltineRichard Haseltine Posts: 111,949
    How far are you getting? You need to seelct the object, open the Surfaces pane, go to the Editor tab, select the surface you want to chnage (first and last steps can be combined by using the Surface Selection tool). You can then either drag your map onto the property you want (probably Diffuse Colour or Base colour, depending on which shader is applied) or click the micro-thumbnail next to the colour picker for the property and select Browse to load your image.
