Questions on making/adding new Textures for an outfit
Turk_WLFTurk_WLF Posts: 177
I got the Genesis (American) Football Uniform & it has templates so I could make my designs. I have no problem using the design but where I’m not sure about adding it to DS 4.6 because I never have done anything with .duf file before. Could someone point me towards a guide or walk me through how to add my own.
Thanks,
  • Richard HaseltineRichard Haseltine Posts: 112,021
    If you mean you want to apply a custom texture, you use the Surfaces pane - the simplest method is to open the pane (from Window>Panes(Tabs)), switch to the Surface selection tool, and click on the are of the outfit you want to texture. Once you have the right area(s) selected go to the Diffuse Colour setting in the Surfaces pane, click the tiny thumbnail to the left of the colour bar, and select browse from the menu to select your new map.
