Holes in characters skins?
linus3424linus3424 Posts: 2
edited March 2021 in Daz Studio Discussion
I've noticed that some characters ive purchased have holes in their skin - is there something i can do to fix this myself?
Here's a quick printscreen with  a blue skin to highlight the issues im experiencing.
Post edited by Chohole on
  • hansolocambohansolocambo Posts: 649
    edited March 2021
    "some" characters ive purchased
    Maybe should you share the name of the characters you bought so that people who also own it can check on their side and potentially give you an answer.
    There are hundreds if not thousands of DAZ female bundles available. Hard to answer when we don't know which one's the one used on this screenshot.
    Post edited by hansolocambo on
  • linus3424linus3424 Posts: 2
    edited March 2021
    Sorry, you're right!
    The character used above is Apryl
    https://www.daz3d.com/apryl-for-genesis-8-female
  • on first glance i'd normally say it's a collision error between a fitted item and the base mesh. See it more with skull caps for hair and the head, but can happen any where.
    It also kinda looks like one of the textures is misapplied, kinda looks like the fingers are in the forearm.
    Might just be a broken texture, try reapplying the base material and see if it makes a difference.
    If that's not the case, try removing one map, undoing between removals, at a time to see if that clears the issue. remove, render, undo, remove, render, undo, etc.
  • lilweeplilweep Posts: 2,881
    "some charaters i've purchased" = apparently just one character...
