Is there anyway to filter out the Poser files coming to DIM?
iSeeThisiSeeThis Posts: 560
I use DAZ Studio alone (even if I have Poser Debut). I've never needed Poser items. Do we have a way to forever filter them out. I nowadays have to check PS and PoserCF items manually. Very boring task.
  • kaotkblisskaotkbliss Posts: 2,918
    Lets see if I can get this up before someone else answers :P
    When you log into your DIM, go to your settings (the little gear in the upper right corner) click on the "downloads" tab and uncheck anything you don't want to show up in your DIM when it shows you what's ready to download
    There is a "Download Filters" button at the top left on the "Ready to Download" tab.
  • iSeeThisiSeeThis Posts: 560
    edited October 2014
    Arrrrrrk!!!! Why didn't I see that? Thank you kaotkbliss and jestmart!
    Post edited by iSeeThis on
    edited October 2014
  • fixmypcmikefixmypcmike Posts: 19,735
    DO you have "DSON Importer for Poser" checked in the Download Filters?
    Note that you will still see some Poser downloadables — some products are Poser-only with no native D|S-format files, some have Poser objects but the D|S installers only contain the D|S materials files (not the object or texture files).
    Note also the DIM should let you see the Poser files in these cases, but every now and then there's a hiccup in the flags that tell DIM to do that. When it happens, put in a support ticket and it'll be fixed.
    And don't forget the process of converting everything in the store to support DIM downloads is only almost complete — some older items are still only downloadable manually from your Product Library page in the DAZ store.
    Thank you fixmypcmike. I saw that almost immediately after I asked for it. Didn't see you reply 2 minutes after I delete my question, sorry.
    Now I understand it clearly. Thank you!
    I keep forgetting this bit — if you go to your Product Library page and enter "dim::false" (note the two colons) into the filter box, you get a list of everything you've bought that DIM doesn't yet know about.
    Woah, I am going to have to try that and see what (if anything) pops up! thanks for that tid-bit!
  • KharmaKharma Posts: 3,214
    this trick isn't exactly foolproof as it showed me 2 pages of files and several of them I did retrieve through Dim even tho it's telling me they aren't available through DIm
    In particular, bundles sometimes have their own pages in the Product Library, but DIM only shows the individual products inside the bundle.
