Bedding and Beyond
jodycourjodycour Posts: 137
How do you use bedding and beyond? I've downloaded the product but when I click on a sheet or bedding it doesn't give me any options to use! How does this product work?
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Do you mean one of the Beyond Bedding sets - http://www.daz3d.com/beyond-bedding or http://www.daz3d.com/beyond-bedding-for-poser ? They are shader presets for DS or material files for Poser, you need to select the item and, if it isn't one of the sheets they are designed for, the surface(s) on the item that you want to apply the material to before you apply the preset.
  • jodycourjodycour Posts: 137
    Yes it is the Beyond Bedding sets! I'm using Daz 3d 4.6 and when I click on the sheets it doesn't give me anything to work with isn't this suppose to give you the ability to like wrap the sheets around a figure? All I see present are the shaders to change the colors or the textures of the sheets!
  • Cris PalominoCris Palomino Posts: 13,051
    These are shader presets. You need to have something to put these on. The set, as the description says, was inspired by Jepe's set of Satin Sheets, but can be used on other things, even clothing. To use them, the object you're going to use them on must be loaded and selected. In the Shader tab, select the name of the object to select all its surfaces (or select which surfaces you want the preset used on) and then apply the preset.
  • KhoryKhory Posts: 3,854
    I think what your looking for is the morphs that the sheets have. Each sheet has several morphs that add extra "drapes" to the sheets for each pose. So.. Once you have a pose selected and the matching sheet then select the sheet in the scene and then go to your properties tab. If you look at the bottom of the list you will see morphs. Click on that and then you will get all the drape options for that sheet. Each sheet has a variety of options that will alter the drape.
  • FirstBastionFirstBastion Posts: 8,090
    You have to grab one of the actual models from Jepe's store: http://www.daz3d.com/jepe
    plenty of choices for the different characters
