Fluidos II Issue
Hey everyone,
Just picked up this plugin and found the tutorial to start the learning progress. I'm not sure what I have done wrong but many options seem to be missing. I purchased from the Daz store and installed using Daz Central. I see that I have a serial key but not sure if or where I need to put that so it can be activated, if it isn't activated already that is. I have not gotten a notification or anything about activating it.
After everything was installed from Daz central I created a new scene and went to add the domain, except, there is not an option for a Fludios Domain under the create menu anywehre. So I went ahead and loaded an already created scene so I could mess with that. It says that some items are missing and need installed, so I do that and the scene loads. The weird thing with that is, it says that everytime I load the premade scene. After I install what is needed, this premade scene has a Fludios Domain in the scene tab but when I click on it, it does not have any parameters other than the default ones you get with any object / item. It is confusing me unfortunately lol.
I attached an image of the error it gives me when I try to load any premade scene. What is needed installed fine it seems just I can't get anything to work it seems.
Any help in the matter is much appriciated.
Regards, and thank you in advance.
279 x 332 - 24K
  • Richard HaseltineRichard Haseltine Posts: 112,036
    The serial number goes in Help>About Installed plug ins as I recall. Restart DS after entering it and you should be good.
  • Dark45Dark45 Posts: 94
    Thank you so much, that did it, figured that would be in a readme or something for new users lol.
