Show asset in -> mapped folder not working
I've installed Daz3d on a seperate SSD. All my content is on the same SSD. Most of it is manually installed. When I right click on anything in the content window and click Show asset in -> mapped folder nothing happens.
This did always use to work on my old pc.
Anyone any clue?
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Do the files load? Do they have metadata (content type tags at top-right,, appear in places other than the Daz Studio fromats/Poser Formats containers in the Content Library)?
  • Yes, they all load just fine. I don't see any meta data but how is the required for going to the mapped folder?
    I was just trying to look for oddities that might account for the issue - but if the files actually load I'm not sure. Where are you right-clicking (I mena in which pane, and which container in the pane)?
    I am clicking in the content library. See picture below. When I click on it simply nothing happens.
    995 x 1550 - 702K
  • vukiolvukiol Posts: 66
    Following, i have the same issue but in the smart contents panel
    I see, in search results. Well, it works for me with the CMS metadata working. What happens if you choose Show In Products?
    My issue is similar
    Panel: smart contents
    Action: Show in Content library/Mapped Folder
    Result: Panel switch only, the content folder is the one already selected
    This is the only action i have issue with.
    Show in products works for me.
    Same thing.
    I think it probably is related to metadata, though I agree one would expect it to work regardless for a file system location. Are the files in their default locations or have you moved them (or manually installed to a non-default location)?
    I have installed them Daz3d on a seperate SSD. The content is in the default folder of the Daz Studio installation (F:/Applications/Data/DAZ 3D/My DAZ 3D Library). Sorry I didn't mention this properly before. I do think the problem is somehow related to it but I can't figure out a solution.
    That doesn't look like the default path, and does look as if it might have issues (the data folder might indicate that  F:/Applications/ is a content directory). It's also possible that Windows is protecting the Applications folder as it does Program Files, which might well cause issues.
    Thank you! I suppose I just wasn't properly thinking myself.
    I first tried to give all users all permissions to the Applications folder. This changed nothing.
    After that however I moved the "My DAZ 3D Library" folder out of the Application directory and placed it straight on the F: disk. Now it works again!
    Thanks for your responses and solution!
