• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
EXPORTING HIGH POLY MORPHS TO CINEMA 4D
developercodeinedevelopercodeine Posts: 0
March 2021 in Cinema 4D Discussion
Hey ther, I cant for the life of me figure out why any 3d model i export from daz to cinema loses quality.  i have all these nice add ons to increase detail and that detail dissappears when i export. The poly is nice and high in daz then when i export it , poof gone back to low poly.... Is there any solution for this? id like to export my model with all of its morphs and detail for animations. Thanks
  • SquishySquishy Posts: 725
    March 2021
    what steps are you taking to export exactly?
  • developercodeinedevelopercodeine Posts: 0
    March 2021
    Im using bridge, or exporting manually with morphs as an fbx.
    March 2021 edited March 2021
    I don't know about or use bridge but what options are you using for FBX, what steps and options are you taking exactly?
    e: It doesn't look like exporting to FBX with Morph Targets checked actually works, although I can tell you that it works importing FBX from Cinema to DAZ Studio. It only exports the final shape used and even then doesn't treat that as a morph target, it converts it to the base geometry. You're correct also that it won't export the subdivided mesh, but you can at least add a subdivision generator once you import the figure into Cinema, that will give you pretty similar results in the end.
    Maybe DAZ support will have better answers, sorry.
    Post edited by Squishy on March 2021
  • autodolorautodolor Posts: 70
    May 2021
    Export as Obj, or alembic (Sagan Ogawa exporter, the old Exporter as HDF5, incompatible now..).
    Import the "daztocd4.fbx" in the plugin in C$D, amd merge the alembic...
    Remap txtures, and solved-
  • mikael-aronssonmikael-aronsson Posts: 605
    June 2021
    FBX always export at base resolution, no HD or even high resolution meshes will be exported, you just get the crappy base resolution, you can subdivide after you import it into C4D though even if you will not get the same result as in DS
  • piefr1piefr1 Posts: 13
    March 2022
    i succed at exporting at full rez with fbx 2020 but i have problems with the morphs once in c4d.
    And if you subdivide in c4d you're gonna mess the morphs again !   It's too bad because in marvelous designer we need a high quality mesh to avoid many problems
    March 2022
    plus i  am getting bigger and bigger files anyway... so....
    March 2022
    it's an animation where i use kitt breathing morph the problem in marvelous designer is visible
    by the way thanks to true plastic for his skin shader : 15s render with octane
    2560 x 1080 - 1M
  • pixel8tryxpixel8tryx Posts: 7
    April 2022
    Wow, really!  I haven't tried that since way before the bridge.  I've only gotten high poly out of the OBJ export but it's been fairly detailed.  I was seriously let down when I first started exporting FBX and saw how few polys I got.  I was terribly jealous of all these amazing renders and couldn't figure out how they did them with the models I was getting.  But then I figured out I just couldn't have my cake (rig) and render (in high rez detail) too.  So I pose in DAZ Studio now quite often and export an OBJ if I'm going to play with a closeup face.  For anything else at a distance, that I move around a lot, the FBX is just fine.
    February 2023
    even in unreal engine you can export meta human full rez in fbx so the problem is not fbx but daz
    February 2023 edited February 2023
    if you lock high resolution and export fbx it will export high rez with the morph .... it works with genesis 3  and it 's perfect when imported in c4d ...........;i didn't try genesis 8 or 9 but i will
    Post edited by Richard Haseltine on February 2023
    February 2023
    export fbx 2020
    February 2023
    but when retargeted it's a mess   i dunno why
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
