Multiple Scripts fail to load. MARSA Anaglyph3D - Dial Fusion - Maps Copier - Spring Dynamics
Has anyone had any issues loading scripts?  I'm trying to isolate what's causing the error.  It's only happening to recently purchased utilities (MARSA Anaglyph3D, Dial Fusion, Maps Copier Gatherer Renamer, Spring Dynamics) .  I tested many older ones and they load fine (Map Master Pro, Ultra Scatter Pro, Brow Remover, etc).  Though I did just buy Pose Fusion Plus and it does load. Attached is the error message and my computer stats.
The log file just says:
2021-03-05 22:49:44.405 Loading script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80505/scripts/riversoft art/anaglyph3d/marsa anaglyph3d.dse.enc
2021-03-05 22:49:44.406 Failed to load script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80505/scripts/riversoft art/anaglyph3d/marsa anaglyph3d.dse.enc
2021-03-05 22:49:51.249 Loading script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80593/scripts/dial fusion/dial fusion.dse.enc
2021-03-05 22:49:51.257 Failed to load script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_80593/scripts/dial fusion/dial fusion.dse.enc
2021-03-05 22:49:55.693 Loading script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_79911/scripts/v3digitimes/maps copier gatherer renamer/v3dmc maps copier gatherer renamer.dse.enc
2021-03-05 22:49:55.694 Failed to load script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_79911/scripts/v3digitimes/maps copier gatherer renamer/v3dmc maps copier gatherer renamer.dse.enc
2021-03-05 22:50:01.532 Loading script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_79911/scripts/v3digitimes/maps copier gatherer renamer/v3dmc maps copier gatherer renamer.dse.enc
2021-03-05 22:50:01.533 Failed to load script: C:/Users/DelForceOne/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_79911/scripts/v3digitimes/maps copier gatherer renamer/v3dmc maps copier gatherer renamer.dse.enc
I tried unistalling them and reinstalling, because that's helped me once before.  I read up on how to use them to make sure I had everything selected properly.  Though I haven't seen anyone else having an issue in the forums so it doesn't seem to be a common issue.  If anyone can help, I so looking forward to using these products.
503 x 187 - 18K
493 x 379 - 31K
  • namffuaknamffuak Posts: 4,513
    You installed these with Connect - and it looks like the install didn't work correctly; they should be dse, not dse.enc.
    Have you tried installing them with DIM or manually, I wouldn't install anything with Connect and especially not scripts, as Connect uses non-standard paths for installation.
  • VerazoazenzaraVerazoazenzara Posts: 12
    edited March 2021
    My goodness, I reinstalled through DIM and they all function smoothly now.  Thank you!
    Post edited by Verazoazenzara on
