Dress does not work with sitting poses
Hi,
I struggle right now a bit and... that frustrates me :(
I use this:
https://www.daz3d.com/dforce-peasant-dress-for-genesis-8-females
When I use any sitting poses, the bottom part of the dress doesn't angle.
It have a JCM for sit, but that seems to not work correct.
Changing from autofollow to redirect does also not help.
I loaded the prop new, maybe the weightmap was wrong but... nope, it still happen.
I can try to move the regions manually but that also doesnt look good.
Any advice for me?
669 x 728 - 50K
496 x 351 - 21K
  • Doc AcmeDoc Acme Posts: 1,153
    It is a dForce item.  Have you run a Simulation on it yet? Doesn't appear to have.You might need a chair or object for that cloth to reat to as well.
  • LeanaLeana Posts: 13,617
    edited March 2021
    Most dresses don't adjust automatically to sitting poses (or even leg poses), they either have "sit" morphs or various morphs/bones to adjust the skirt pose manually.
    Another option would be to use a dForce simulation (not sure if a simple simulation from default pose would work or if you'd need an animated one to go from a standing pose to the sitting one).
    Post edited by Leana on
  • LoonyLoony Posts: 1,817
    edited March 2021
    I did try with disabling the shins/feet for dforce, but that looked wired, without that it would not dropp correct.
    "Another option would be to use a dForce simulation (not sure if a simple simulation from default pose would work or if you'd need an animated one to go from a standing pose to the sitting one)."
    Maybe... it will work with memorized Pose, I should try that.
    Post edited by Loony on
    okay update, I wanted to try with the memorized pose but... it start IN the block ;(
    I think the best thing I can do is just use a other pose, then the lady will just not sit :/
    889 x 827 - 63K
    1032 x 920 - 110K
  • barbultbarbult Posts: 27,630
    edited March 2021
    The product is fine. You need to do an animated simulation with the timeline and start with the block moved away. Then move the block under her as the animation progresses to the sitting pose. Watch this tutorial, especially around 39 minutes.
    1498 x 1940 - 280K
    Post edited by barbult on
    but my problem with timeline stuff is always, it brings me into problems with other figures in the set :(
    I wanna "play" on timeline 0.
    Ok I think that will work, will try to work on Frame 30 then, I make comics so I have a lot shots with the same setting, thats why timelines are most times a problem :(
    1075 x 536 - 60K
