Deleting part of a product
I got earrings that load into scene only as couple. But i need only one earring. I can temporarily hide the second one through geometry editor, but this is only untill i load the scene again. Then i have to make same long way through geometry editor to hide it again.
Is there any way to hide it until i decide to unhide it by myself? Or maybe there is a way to delete the second earring?
  • Hey!
    1. You could try hitting ALT+SHFT+G.
    2. Select the geometry you don't want.
    3. Then, right click while still in Geometry Editor (ALT+SHFT+G).
    4. Go to Geometry Assignment, then select Create Surface From Selection.
    5. Name the new surface, go to your surfaces pane and the change "Opacity" to 0%.
    6. Then go to File, Save As Material Preset.
    7. Then simply apply that Mat Preset each time you need it.
  • after you make the one innvisble .. you can delete hidden polygons...  then save the single as a scene subset.
  • TaozTaoz Posts: 10,345
    You could try deleting the geometry, I've done that quite often without any problerms.
  • ant2505ant2505 Posts: 71
    ParallaxCreates, thank you, it works.
    Alan, or Taoz (or anyone else), could you, please, describe the way i can delete polygons?
  • jim_doriajim_doria Posts: 133
    Deleting polygons: With the Geometry Editor tool active, select polygons, right-click in viewport.
    At the bottom of the menu is Geometry Editing. Choose Delete Selected Polygons.
    Warning: no undo.
    Thank you, Jim!
    Interesting thing: deleting polygons from scene doesn't affect it’s size. Is it the way it should be? And will it speed up rendering?
    ant2505 said:
    Thank you, Jim!
    The coordinate information takes very little memory. In general geometry information for an object takes about 5-10% of the amount of memory that the textures and maps take and the textures will still be loaded in whole.
