Shapes applied randomly
edited October 2014 in Daz Studio Discussion
Hi
I make a figure, close the file, then when I open it, the shape of an older figure was aplied to it.
Thanks
  • edited December 1969
    I just realized that every new genesis figure is now set to load with this shape I made.
    Weird.
  • Cris PalominoCris Palomino Posts: 13,051
    Can you provide more information? What figure are you using? How did you save it?
    Weird.
    It appears that you have overwritten the Base Genesis DUF file. To correct this, load Genesis as normal, then go to the Parameters pane, select 'Currently Used', and zero out anything in there. Once Genesis is back to normal, resave it again (over the original DUF file)
    If the above doesn't work, you may have some morphs installed from a free site that are causing problems, what morphs for Genesis have you installed recently?
    This is happening with I figure I've shaped. When I load or open it, a shape of an older one is applied to it. How I solve that?
    That’s happening both to Scenes files, Characters preset and Character/prop assets.
    I've used this morphs before with no harm.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Rather than have duplicate discussions I've locked this thread in favour of http://www.daz3d.com/forums/viewreply/697821/
