Gizmo bigger
riomairiomai Posts: 44
edited March 2021 in Product Suggestions
To the developpers. Please, can you implement some new gizmo style ? I need a bigger universal gizmo, please. What exactly I need are just some bigger rotate circles on universal gizmo (and more detailed, like in rotate gizmo), because it's hard to rotate using this tool. Something easier to click, please.
A much larger universal gizmo, with thicker and slightly shaded colored circles and that appears with a shortcut click and disappears when you release the click... This can be awesome... PLEASE, HELP MEsad
Thank you.
Post edited by riomai on
    Why do you even use the gizmo? I have been using DS for years and never use it for posing.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,709
    if you want them bigger you gotta feed them after Midnight!devil
  • SevrinSevrin Posts: 6,314
    But don't get them wet, because you don't want more than one.
    Seems like it's stuck, like so much of DS, in the era of low resolution monitors. I don't think the gizmo will get any bigger until there's a general UI overhaul that allows more customization and better accommodates high resolutions.  I use it for translation, but not so much for rotations, because it's sort of a crapshoot which way it will rotate.
    I am also too much of an engineer to use something that unprecise to do anything
    +1. Don't often use the parameter sliders either, usually typing in numbers rounded to 0, 1 or 2 DP as the situation requires.
