Morph Dial Suddenly Defaults to 100%
jim_doriajim_doria Posts: 133
edited March 2021 in Daz Studio Discussion
I seem to be having the same problem as in this thread:
https://www.daz3d.com/forums/discussion/comment/4260591/
I have the Omari for G8 character on my system, and I've had the product for months & months.
But I must have done something wrong recently because now every character I load appears with the Omari Head morph dialed up to 100%. This even happens with the default G8.0 character.
I can always just slide it back down, but ideally I'd like to fix it. In the other thread, Richard Haseltine said:
if you click on the Controllers tab at the bottom of the (parameter settings) dialogue one of those is likely to be the culprit.
So there is one controller there, but I have no idea what to do with the "culprit" now that I've caught it.
Thanks!
EDIT: I went back and looked, and it turns out the whole character morph is being dialed in at 100%. I didn't notice at first because the full character morph dial and the body morph dial, while reading 100%, are grayed out as if this was the default value. Only the head morph dial is "lit up" at 100% as if that's the one not at its default setting. However, doing a parameters reset on it doesn't change its value or its lit-up state.
612 x 271 - 30K
Post edited by jim_doria on
    To fix any ill-behaving (non-zero default value) morphs, do as follows;
    1. Open DS and load "Genesis 8 Basic Female" (to an empty scene)
    2. Help->Troubleshooting->View Log File (clear the log, close it and select "Save" when asked)
    3. Left Click at "Active Pane Options" tab->Preferences->Choose "Show Hidden Properties" (part 4 zeroes only 'visible' dials)
    4. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
    5. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
    6. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
    When saving "Modified Assets" DS shows a dialog and asks for confirmation;
    "The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
    Close DS and wait -> Open DS again and load "Genesis 8 Basic Female"
    Help->Troubleshooting->View Log File (Save the logfile somewhere you can easily find it)
    If the above procedure didn't fix the problem, attach the saved logfile to your post.
  • jim_doriajim_doria Posts: 133
    Thank you PerttiA that did the trick! I've added these instructions to my collection of DAZ notes should I bump into this again.
    Ditto that! Thanks a lot PerttiA! This is the best advise for fixing wrong default values I have seen. Its perfect!
    Never have I been so happy to be able to render that bland default face :D
    Ok, mind showing step by step via images. What's the "active pane options" tab?
