Hexagon Manipulators - Can you change the movement smoothness/iterations?
As usual, sorry if this has already been covered.  I tried a search... but, well, the forum search here is... broad.  Please link topic if it exists.
When I use the manipulators in Hexagon, the object jumps by 0.100.  For example, 0.500 to 0.600.  It seems it wasn't always like this, that maybe I changed something without knowing, or it's just my imagination, but I want that to be much less, such as 0.010.  Especially when working with points, it's a real bummer to have to change values in the Position fields to get finer movements.
I've dug through all the menu items and can't seem to find a place you can change the menipulator transition values.  Changing the tranistion/rotation "speed" in preferences doesn't have any affect, and apparently can't be set below 0.500.
 Thanks in advance for any help! :)
  • Dead Cow DigitalDead Cow Digital Posts: 26
    edited March 2021
    NEVERMIND!  I "reset all preferences to default" and that seemed to fix my problem, though I'm still at a loss about which "preference" setting affected the transition iterations (and how it was changed in the first place since I never edited any preferences to begin with).
    Post edited by Dead Cow Digital on
  • AscaniaAscania Posts: 1,856
    You probably turned snapping on.
