Install manager not working
artofdawnartofdawn Posts: 0
Just submitted this as a helpdesk ticket since I couldn't find any solutions online, but I figured it wouldn't hurt to bring it up and see if anyone out there experienced a similar issue and solved it:
I recently changed computers. On my old system (Windows Vista 64-bit Home Premium) DAZ and the Install Manager worked fine, but on the new one (Windows 7 64-bit Home Premium) the Install Manager keeps closing whenever I try to download. I am able to launch it fine and log into my account and see all my purchased and free items for download, but it doesn't matter what I select or how much, as soon as I hit the 'start queue' button the IM window disappears. If I bring up Task Manager it still shows under the Processes tab and is taking up memory, but nothing more happens.
I have tried uninstalling and reinstalling everything DAZ related but it keeps happening. I was able to install Studio by manually downloading the application instead, but I have over 40 items waiting for download and so it's going to be a big pain manually adding everything, not to mention it seems like that will cause problems if I ever get IM working again.
I've tried closing down all the background programs I can think of that might cause issues, except Microsoft Security Essentials, but MSE never interfered on my old system. The only thing I have installed that wasn't on the old system is Adobe Creative Cloud, but I turned it off from running except when I need it.
  • DoctorJellybeanDoctorJellybean Posts: 10,150
    Have a look at the DIM log file and see if it says anything. Start DIM, click on the Settings icon (upper right gear), and then hit the Show Log button.
  • artofdawnartofdawn Posts: 0
    Here's the latest log from me trying to download the "Add On For Zombie" pack I'd purchased. Others seem to be similar, just with different filenames depending on what I tried.
    +++++++++++++++ Install Manager 1.1.0.27 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.6
    Locale: en_US
    Running on Windows 7, Build 7601, Service Pack 1
    Physical Memory:
    Total: 3.9 GB (4294967295)
    Avail: 3.9 GB (4294967295)
    Virtual Memory:
    Total: 3.9 GB (4294836224)
    Avail: 3.8 GB (4156137472)
    Current Memory Usage: 38%
    Current DateTime:
    Loc: Thu Oct 16 19:25:20 2014
    UTC: Fri Oct 17 02:25:20 2014
    Application Data:
    Location = C:/Users/Dawn/AppData/Roaming/DAZ 3D/InstallManager
    Disk Total: 238.3 GB (255953203200)
    Disk Avail: 141.6 GB (152125599744)
    Reading dzInstall.ini
    Current Account: Account
    Current Download Path:
    Location = /DAZ 3D/InstallManager/Downloads
    Current Content Install Path:
    Location = E:/Daz3d Content
    Disk Total: 1.8 TB (2000396742656)
    Disk Avail: 1.7 TB (1903380488192)
    Current 64-bit Software Install Path:
    Location = C:/Program Files
    Current 32-bit Software Install Path:
    Location = C:/Program Files (x86)
    Connected to CMS: 4.8
    Processed 30 products with 62 unique product downloads
    WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 3 unknown for QWidget)
    WARNING: Could not set permissions on file: /DAZ 3D/InstallManager/Downloads/IM00015213-01_AddOnForZombie.zip.{33c7f639-10b7-5d4c-e05d-b96343a5363c}.part
    WARNING: Error opening save file "/DAZ 3D/InstallManager/Downloads/IM00015213-01_AddOnForZombie.zip.{33c7f639-10b7-5d4c-e05d-b96343a5363c}.part" for product 15213-1, "Add On for Zombie": could not presize file
    WARNING: Error opening save file "/DAZ 3D/InstallManager/Downloads/IM00015213-01_AddOnForZombie.zip.{33c7f639-10b7-5d4c-e05d-b96343a5363c}.part" for product 15213-1, "Add On for Zombie": The system cannot find the path specified.
  • fixmypcmikefixmypcmike Posts: 19,729
    I notice that your download path doesn't start with the drive letter. If you change it to include the drive letter, does that solve the problem?
    Where would I change that?
    Click on the Settings icon again, then check the path on the Downloads tab. Change if needed.
    I'll have a look when I get home. I assumed that the Download Path was omitting a drive letter because it was just a subset of the Application Data setting, but now that I'm looking at some other people's logs, yeah, maybe that's exactly the problem.
    That did the trick! Weird, it had just somehow defaulted to not having a drive letter, even when I reinstalled.
    Thank you!
    Glad it worked.
  • Hello! The same thing is happening to me, but a little different. I just recently downloaded DAZ Instal Manager but every time I attempt to log in online, a white tab comes up and says "DAZ Install Manager Has Stopped Working". I can only sign In offline but I don't know what to do. No one will help me and really need it
  • Here is my DIM log file.
    +++++++++++++++ Install Manager 1.4.0.17 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 64
    Qt Version: 4.8.7
    Locale: en_US
    Running on Windows 10, Build 9200, No Service Pack Installed
    Physical Memory:
    Total: 3.8 GB (4119900160)
    Avail: 684.4 MB (717672448)
    Virtual Memory:
    Total: 127.9 TB (140737488224256)
    Avail: 127.9 TB (140737286414336)
    Current Memory Usage: 82%
    Current DateTime:
    Loc: Wed Apr 29 11:40:34 2020
    UTC: Wed Apr 29 15:40:34 2020
    Application Data:
    Location = C:/Users/jujus/AppData/Roaming/DAZ 3D/InstallManager
    Disk Total: 28.1 GB (30201081856)
    Disk Avail: 2.7 GB (2935291904)
    Location = C:
    Location = C:/Program Files/DAZ 3D/DAZ3DIM1/My DAZ 3D Library
    Starting CMS...
    Error connecting to CMS. Cannot be started by client.
  • Richard HaseltineRichard Haseltine Posts: 111,674
    4GB of system memory is going to be very, possibly impossibly, limiting - though I don't think it would  explain the crashing. What security software are you running?
    You don't have a lot of disc space available: Disk Avail: 2.7 GB (2935291904)
  • edited April 2021
    uggg same issue for me too. install manager works fine on my old Win8, but now my faster Win10 is not working. i installed several times.
    The row that says "Cannot locate dzInstall.ini" doesn't seem to affect my Win8 install as the Win8 version runs fine.
    Both Win8 and Win10 run the same Mcafee install and account.
    i have followed the thread and ruled out those issues. any other ideas as the help support is on a lag of 4-6 weeks? Appreciate any help. thanks.
    2021-04-13 08:47:24.743 +++++++++++++++ Install Manager 1.4.0.67 starting +++++++++++++++++
    2021-04-13 08:47:24.745 OS bits: 64
    2021-04-13 08:47:24.745 Platform bits: 64
    2021-04-13 08:47:24.745 Qt Version: 4.8.7
    2021-04-13 08:47:24.745 Locale: en_US
    2021-04-13 08:47:24.745 Running on Windows 10, Build 9200, No Service Pack Installed
    2021-04-13 08:47:24.745 Physical Memory:
    2021-04-13 08:47:24.745 Total: 15.7 GB (16944979968)
    2021-04-13 08:47:24.745 Avail: 11.6 GB (12515319808)
    2021-04-13 08:47:24.745 Virtual Memory:
    2021-04-13 08:47:24.745 Total: 127.9 TB (140737488224256)
    2021-04-13 08:47:24.745 Avail: 127.9 TB (140732949450752)
    2021-04-13 08:47:24.745 Current Memory Usage: 26%
    2021-04-13 08:47:24.745 Current DateTime:
    2021-04-13 08:47:24.745 Loc: Tue Apr 13 08:47:24 2021
    2021-04-13 08:47:24.745 UTC: Tue Apr 13 12:47:24 2021
    2021-04-13 08:47:24.746 Application Data:
    2021-04-13 08:47:24.746 Location = C:/Users/rey_v/AppData/Roaming/DAZ 3D/InstallManager
    2021-04-13 08:47:24.746 Disk Total: 475.6 GB (510770802688)
    2021-04-13 08:47:24.746 Disk Avail: 369.0 GB (396241752064)
    2021-04-13 08:47:24.746 Reading dzInstall.ini
    2021-04-13 08:47:24.746 Cannot locate dzInstall.ini
    2021-04-13 08:47:24.747 Current Account: Account
    2021-04-13 08:47:24.747 Current Download Path:
    2021-04-13 08:47:24.747 Location = C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads
    2021-04-13 08:47:24.747 Disk Total: 475.6 GB (510770802688)
    2021-04-13 08:47:24.747 Disk Avail: 369.0 GB (396241752064)
    2021-04-13 08:47:24.747 Current Content Install Path:
    2021-04-13 08:47:24.747 Location = C:/Users/Public/Documents/My DAZ 3D Library
    2021-04-13 08:47:24.747 Current 64-bit Software Install Path:
    2021-04-13 08:47:24.747 Location = C:/Program Files
    2021-04-13 08:47:24.749 Current 32-bit Software Install Path:
    2021-04-13 08:47:24.749 Location = C:/Program Files (x86)
    2021-04-13 08:47:24.749 Disk Total: 475.6 GB (510770802688)
    2021-04-13 08:47:24.749 Disk Avail: 369.0 GB (396241752064)
    2021-04-13 08:47:24.749 Starting CMS...
    2021-04-13 08:47:24.749 Error connecting to CMS. Cannot be started by client.
    2021-04-13 08:47:28.962 Current Account: Account
    Post edited by rey_ve_2c205a4c93 on
  • Geminii23Geminii23 Posts: 1,328
    I just found this thread.  I am having this same problem on a brand new Windows 10.  DIM will not load up at all.  Whenever I try to login and start the app just vanishes.  no error message.  nothing.
    I am only able to go in offline mode and I am able to start and stop CMS from within DIM.  I need this fixed desperately.  I bought this machine specifically for DAZ and have a big project I need to get working on.
    Please attach the log, which should be in C:\Users\Your username\AppData\Roaming\DAZ 3D\InstallManager
    What you can try, is resetting the database: in DS, click the hamburger menu on the Content Library pane - Content DB Maintenance - Reset Database. Quit DS, wait a min or so and try launching DIM again. If it works, then repeat the above process but instead of resetting the database, select Re-import Metadata.
    Here's the log file from Install Manager. But I don't see anything indicating why it crashes when I try to login.
    txt
    txt
    log.txt
    6K
    Did you try my steps resetting the database?
    Hi.  Unfortunately resetting the DB and re-import meta had no affect.  DS still crash on loading a figure. I see a lot of warnings in the log.
    txt
    txt
    log_5102021.txt
    8M
    @DoctorJellybean - I just did complete uninstall of everything again.  Followed all steps to ensure clean uninstall.  Then download fresh copy of DIM from my account on DAZ Store.  I checked the Windows event viewer to see what is happening when DIM fails to login and load.  See attached.
    Any ideas?
    684 x 220 - 41K
    So to add further to my frustrations...I just installed DIM on an old Windows 10 laptop.  It worked fine.  I then tried to copy the entire folder with the LIBEAY32 onto my new box and see if it would work.  Nope.  Gives the same error.  I then tried to disconnect Wifi and run ethernet and tried again.  Still same problem.
    Does anyone know how to fix this dll error?
    Do you have any Anti-virus\malware apps? If so, try disabling them.
    Only the built-in stuff with Windows 10.
    Ok, one thing you can try. Open DIM in offline mode, click on the Settings gear icon and click on Basic Settings. Click on the path listed for Content Database Base. It should open a File Explorer window. Close DIM, make sure DS isn't running, and rename the ContentCluster folder (e.g. ContentCluster Old) in File Explorer. Start DIM again and try logging in. If that didn't work, you can rename it back to the original name.
    Maybe you could create a new account, add that account to DIM and see if it works.
    Ok. Problem solved.  Thanks you very much to @Worlds_Edge for helping me get this fixed.
    I know we are not allowed to post files and what not, so the long and short of it is that there are two files that need to be replaced in the DIM folder. libeay32.dll and ssleay32.dll
    Once those files were replaced I was able to login to DIM and am now installing the 5000+ items from my account.  I'm pretty sure DS will work after this as well.  Since the few people this is happening to seem to have the common factor of getting new laptops or desktops recently, I suspect this is going to be a bigger problem moving forward if DAZ doesn't address it soon.  It must be a conflict with a new driver or windows update.
  • SDevSDev Posts: 158
    edited May 2021
    Thanks, yep, that did it. Both dlls are part of an open ssl driver package. Funny, I had them already available in another directory of my Rad Studio compiler set :)
    Info: http://docwiki.embarcadero.com/RADStudio/Sydney/en/OpenSSL#32-bit_and_64-bit_Windows
    Files: https://indy.fulgan.com/SSL/
    Post edited by SDev on
