Applying Older Morphs and Poses to G2
zombiewhackerzombiewhacker Posts: 707
Can someone please explain which programs are required to:
Apply G1 morphs to G2.
Apply V4/M4 morphs to G2.
And also whether poses from G1 and earlier bases (V4/M4 etc.) can be applied to G2.
  • kaotkblisskaotkbliss Posts: 2,918
    I believe poses can be applied universally (although usually with some adjustments) Select the figure then under content library find your pose and double click. The pose won't show up in the smart content tab as it's not listed under compatibility for that model, but I've used Aiko3 poses on genesis2 as well as female poses on male figures and vise-versa...
  • Jonathan BJonathan B Posts: 114
    edited October 2014
    I believe the GenX 2 product and its related add-on files are needed to transfer morphs and shapes from older figures to Genesis 2:
    http://www.daz3d.com/genesis-generation-x2
    http://www.daz3d.com/genx2-addon-for-genesis-2
    I had the older product and it did a decent job of morphing Genesis to a V4 character that I had been using, but I have not had a chance to use the updated product on G2F. The base program with the G2 add-on works with Gen 4 figures and there are additional add-ons for Gen 3 figures as well.
    (You also need the Gen 3 shapes for Genesis to use GenX 2 on the older figures. And you may or may not need one of the Gen 4 shapes packages for Genesis(2) for characters based on V4 and M4)
    Post edited by Jonathan B on
  • LeanaLeana Posts: 13,678
    You also need "Victoria 4 for Genesis 2 Female" if you want to use V4 textures on G2F, and "Michael 4 for Genesis 2 Male" to use M4 textures on G2M.
