White skin render in certain scenes?
I have some scenes that have the white skin render problem and others that do not.  Same model, same skin texture.  I have checked the skin texture in surfaces and it is linked to an existing file.  There is no brickyard folder that I see.  I am running 4.15.0.2 on Windows 10.
  • TheKDTheKD Posts: 2,711
    Usually whn I get a pure white skin issue, it's a geoshell causing it.
  • TBorNotTBorNot Posts: 380
    edited February 2021
    Geoshells have a bug that sometimes turns on or changes visibility.  It's easy to reproduce, delete the figure then undo, and any attachments are now white  You can also delete the Geoshell and undo, and you get either white or weirdly grey skin shadings on all or part of the body (it varies).
    Post edited by TBorNot on
  • tacrectacrec Posts: 12
    How do I fix the geoshell?  I'm new to this, I didn't know I was using one.
    I think too many canceled renders causes it.  I turn off my computer for the night, turn it back on the next morning and the renders are good again.
