Alembic or MDD for animation
Hello everyone. I animate clothes in Marvelous Designer. I use the mdd format for genesis. But, if I use geografts, then the mdd file is not imported into marvelous designer - vertex mismatch.
I tried to do the trick. I created a geoshell for genesis and imported it into marvelous designer. It worked, but with inaccuracies. For some reason, the geoshell inside marvelous designer does not have 100% compliance with daz3d.
Can I use Alembic exporter to export genesis 8F/M along with geografts? Does it work with version 4.14?
  • lilweeplilweep Posts: 2,880
    use the free Sagan alembic exporter - link somewhere in this forum
    Thanks for your reply. I found a link. Did a little test. It works! Perfect
