Frame Button seems to stop working
This is a tip for new users and old hands like me who may forget since this problem so rarely crops up...
I just spent a half hour restarting DAZ, rebooting my computer, loading different scenes and models, etc, to try to figure out why my Frame Button stopped working. That's the little button on the viewport that looks like a square aiming reticle. My problem was that no matter what character, object, or body part I had selected, clicking the Frame Button wouldn't zoom in on it, and right-clicking the Frame Button didn't aim at it.
My problem turned out to be that somehow I'd managed to activate the Surface Selection Tool. In that mode, the Frame Button does not work normally. I usually hide the gizmos by using the Node Selection Tool, so there wasn't any indication for me in the Viewport that the Frame Button was never going to work right. DAZ Studio helpfully remembers the last tool you use between sessions, so restarting DAZ and even rebooting my computer didn't clear up the problem.
I'm not suggesting anything is wrong with DS, just letting you know that if the Frame Button starts acting all crazy for you, step 1 in resolving the problem is to determine which tool is currently active.
    Hey wait a minute...there's a Surface Selection tool???? How come nobody told me ???
    Cool. Never knew that. I'm always selecting the object, then the Surfaces tab, then scrolling to the surface. This is much much gooder.
    Thanks.
  • 3WC3WC Posts: 1,171
    Actually, the frame button works perfectly in Surface Selection mode. It frames whatever surface you have selected.
  • When nothing is explicitly selected DS treats it as if everything is selected.
  • Thanks for the very useful tip, Inkubo! I was having the same problem smiley
  • Similar issue however slightly different.
    Typically when I was posing the figure I'd select the part I wanted to adjust/pose and then click the LMB selecting (highliting) that part.
    Then I'd RMB click the "frame button" (target with a plus in it) and the specific part/area would lock into the viewing so that I could rotate the camera around only that part/area.
    This all changed the other day and although clicking RMB on the part would focus on that part, rotating the mouse rotated the camera around the entire image, not just the part.
    After a couple minutes I discovered that this condition only ocured when I was in any actual "Camera" render mode.
    When I switched back to "Perspective View" mode the control was normalized again.
    Minor frustration.
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Minor frustration.
    A specific cmera or trying dfferent ones? If it was a specifc camera was it set to Point At something?
