Criminal Case: Bathroom [Commercial]
3dLab
https://www.daz3d.com/criminal-case-bathroom
Criminal Case: Bathroom gives you a unique public bathroom experience with realistic props and assets.
Besides the complete scene, you can create your own place. All props and assets can be moved or removed from the scene as desired so you can have a scene you want. The scene consists of a plenitude of realistic low poly props with 9 camera settings for each scene ready to render and 3 different render settings. All textures and UV maps are optimized for Iray. The mysterious Criminal Case: Bathroom is ready for you!
Post edited by 3dLab on
Realistic Props
Looks great.
How easy would it be to change the room's texture to something more clean? Like without all the graffiti perhaps? Are there different surfaces that one could just apply a different shader to?
Thank you. I designed an old and worn toilet therefore I didnt thought of doing it clean :D
Shell casings for a baseball bat killing?
Sorry. Only markers.
Clay
I'm sure you could add any concrete or porcelein shader you have in your library to the toilet itself, a plastic shader to the seat, and it would look great.
The set, by the way, looks awesome!
After examing all the evidence, I find the assumption that the killing was with a baseball bat to be eronious. It was plant; also deliberate, was the removal of all shell casings!
I was also struck by the inability to open or close doors, or use the toilet for its intended purpose as the lid was stuck down.
All joking aside: is the toilet seat and are the doors rigged?
You're going to use the product only for baseball bat killings?
Thanks
Thanks
Tossed by the perp to confuse the detectives.
:D
:D
