Toon Boy Sam Files. help
jordanb1jordanb1 Posts: 26
Hi just bought toon boy sam & clothing pack and installed daz3d how do i get sam files intl daz3d i cant figure it out, and it says toon boy sam is installed somwhere. I have no idea where or how to get the files open in daz3d cheers
    Have you looked under Poser format?
  • jordanb1jordanb1 Posts: 26
    Where do i find that ?, any help would be appreciated :) thank you
  • LeanaLeana Posts: 13,504
    First thing: if you're looking in the "smart content" tab then there's a good chance you won't find Sam there as it most probably doesn't have metadata.
    You'll have too look in the regular content tab (which IIRC is simply called "content") which doesn't use metadata.
    There you should find at least 2 content directories: one for content in Poser format and one for content in DS format. Sam and his stuff should be located in the Poser content directory, with the figure and clothes somewhere in the "Figures" library, and the materials in the "Pose" library.
    If you still can't find Sam then you'll need to check where it was installed (I assume via DIM?) and if that folder is configured as a content directory in DS.
    fantastic ive now got sam in daz3d studio, how do i lock his hair to his head etc, also is there any underwear for this model?, dont want to upload first tests with a nude model! lol
    Toon Boy Sam doesn't actually come with clothing by default aside from his 'swimsuit' which is basically an alternative texture. However, there is a nice clothing pack for the kiddo which you can buy. Loading the hair should automatically fit it to Sam's head in Daz Studio, so simply selecting Sam and double-clicking the hair in the Content Library should do the trick.
    For reference, you can find it under Hair -> 3D Universe. Sam and Sadie remain two of my personal favourite figures to work with.
    Thanks i cant wait to finally try it out, i found this online , anyway to get the same underwear/swimwear as this?
    http://youtu.be/nNGSKNk2wi4
    Also help on the facial expressions would be great also thanks guys :)
