Custom weight maps lost when converting from G8F to any other body.
I am creating a custom unisex clothing item for G8F. I used the transfer tool to rig it. Then I used the wieght map brushes to clean up the weights and all looks good. Howver, after saving the clothing item, and applying it to a different body, say G8M, then all the custom weights are lost and it looks like it was freshly rigged with the transfer tool.
Is there any way around doing a version for each body?
(Pardon any terminology mistakes, still learning.)
AutoFit in effect transfers a morph from the original figure to the target figure, bakes it in, and runs the Transfer Utility - so yes, it will remove custom weight maps. You might want to look at the Cross Figure Resource Kit https://www.daz3d.com/genesis-8-cross-figure-resource-kit , though I think you'd still need to do some firther work even if it gave usable rsults 9which, as I recall, depends on the type of item)..
Thanks for that. I'll give it a shot and see how well it works.
