I think I deleted something I shouldn't
Sorry if I've put this question in the wrong place.
I can't find the "My Library" folder. To be be clear, NOT the "My DAZ 3D Library" folder which I still have. I had to completely uninstall my old version of DS and do a clean installation of 4.15; could NOT get update to work. The clean install worked, but I wound up with two folders named "My Library"under the content tab. I only meant to remove the old one using the "Remove Base Directroy" option, but it looks like I removed both somehow. I may have had them both highlighted without realizing. Now I have NO folders for "My Library." Any idea how I get it back? Do I have to reinstall DS?
In the Content Library right-click on Daz Studio Formats, click Add Base Directory, and - assuming you are using the defaults - use the browser to select /Documents/Daz 3D/Studio/My Library/.
This... sorta works? I had to manually create a folder in "Documents" called "My Library." THEN it showed up when I used "Add Base Directory." Now the problem is I have no idea what else should be in that folder. I know it contained a sub-folder called "Presets" that contained some of what I'd made myself because I had to hold on to my old copy to save my work, but I can't remember what else it contained. This doesn't seem to have messed with acutally using Daz Studio at all; it still works. It's just a nuissance trying to remember what all was in that folder. Oh well; I've got my presets back at least. Thanks for that.
