Is there a way to prevent Morphs from loading?
I think I may have an issue with a morph, but I don't know which one is causing the problem.
Is there a way to prevent all morphs from loading when opening a .duf file?
Two things are happening, one is that any/all of my saved scenes can't be viewed except in IRAY view in the viewport.
and the Golden Palace anatomy is screwed up.,
Unless you remove the morphs from the morph directory of the base figure, there is no way to prevent them from loading.
If there is a problem that DS considers a problem, then you should be able to find a warning about it on the log (Help->Troubleshooting->View Log)
I think a bad morph got loaded onto some of my saved characters. I had and solved a similar problem with a bad morph by deleting it completely, but I knew which asset to delete.
How do I find the morph directory of the base figure?
Is there a way that I can edit which morphs are being applied?
The problem also hides the golden palace product and I have to reload it.
