Buttons or keyboard to select cameras?
ScavengerScavenger Posts: 2,677
I'm working on a picture and have set up a lot of cameras to help with posing and so forth..
I'm finding the program will lag often, or just basic interface issues, when going to the camera pulldown.
Is there a way, either through keyboard commands, or like a panel with buttons, to be able to just press something and switch cameras? (ala how a realworld director/console would say "show me camera 1, show me camera 3" and press buttons to switch?
Any products or scripts that set something like that?
  • Cris PalominoCris Palomino Posts: 13,062
    You can create a camera preset for the selected camera. You can make a folder/subfolder for presets for what you are working on. If I'm working on a project, I will do a folder for the project and then relevant subfolders. Do one for cameras and then save as a camera preset or use the plus (+) sign on the Content Library tab and choose Camera Preset and selected camera with your camera selected in the Scene Hierarchy.
  • Richard HaseltineRichard Haseltine Posts: 112,087
    Switching between cameras in the scene would be trickier. You could fairly easily write a script that would go to the next/previous camera, but with a lot of cameras that wouldn't be likely to save any time compared to using the drop down. While writing a script to switch to a camera with a specific name would also be easy it would require a different script, and so shortcut, for each camera - and you'd have to be disciplined about naming if you wanted to use the script repeatedly.
