Zbrush Decimation master not working on Manderbulber Fractal
WendyLuvsCatzWendyLuvsCatz Posts: 41,713
edited February 2021 in The Commons
I am going bonkers here, I have used Decimation Master before on other meshes but a 3.8million poly Mandelbulber 3D export will not change it's polycount no mater what I do.
Other options such as saving as a ztool first, duplicating it, making it a polymesh3D don't work either
and trying to export a texture map as is freezes Zbrush for hours and I end up killing it in taskmanager
I can UV map it as uv tiles but pointless if cannot export the texture
otherwise could import it in D|S as is untextured anyway
  • oh it will work if I don't preserve UV's which defeats what I actually want to do as the original has a UV I added but won't export a texture from polypaint
    ( 12 hours later kill in taskmanager)
    and is the one I want to use
    I just need a texture
  • I never solved this, endless googling, tutorials later nothing I am doing is wrong it just won't work on Mandelbulber 3D fractal mesh exports
  • akmerlowakmerlow Posts: 1,124
    Did you also try MeshLab? It's free and allows to do things (but imho, its crazy unstable, though. in most cases it just crashes for me instead )
    https://www.meshlab.net/#features
    Post edited by akmerlow on
    yes but doesn't do what I want, I can make a unified skin in Zbrush and Zproject to it and get a better result
    but not what I want
    I want to use the original object and export a texture and it's too big
