Which one has the fastest rendering engine?
stormqqstormqq Posts: 76
Vue or Carrara ? and which one is most suitable for interior and which one is most suitable for outdoors? and which one is most suitable for rendering complex scenes with less times? please if it's possible post some statistics too.
  • SzarkSzark Posts: 10,634
    I maybe wrong but I cannot see anyone able to answer that as it depends on the scene, the lighting solution used and quality settings. Both can do interiors though Vue was designed for landscapes but does have capabilities to do interior scenes. IMHO Carrara is an all rounder though I use Vue more than Carrara.
  • nightwolf1982nightwolf1982 Posts: 1,333
    Render speed ultimately depends on a combination of what's in the scene, render settings, and your computer's processing power and memory.
  • ArtiniArtini Posts: 10,960
    You may also take a look at the thread "Carrara vs Vue vs Bryce vs ?"
    http://www.daz3d.com/forums/discussion/44348/
    but the answer was Carrara, as usual.
  • StratDragonStratDragon Posts: 3,290
    Bryce does not appear to be in development any longer. it's been feeding pigeons in the park with Hexagon
    Not to mention Bryce is strictly a 32 bit app. Vue has a 64 bit version and IIRC so does C8.5.
    edited October 2014
    and I get the feeling it never will but I could be wrong.
    Post edited by Szark on
  • Atticus BonesAtticus Bones Posts: 364
    If it's speed you're after, Carrara's the only one of those that currently has a plugin for Octane... Just saying.
    yeah but you need a tonne a Vram for big scenes to get the best out of that speed.
    edited October 2014
    All depends on how big the textures are, and that's something that varies wildly from vendor to vendor.
    Stonemason, for example is super efficient. "Urban Sprawl 2" in it's entirety only uses 195MB VRAM!
    Post edited by Atticus Bones on
    Good point. Yeah super efficient modeller too. Not bad for a big set, thanks for that info.
  • FirstBastionFirstBastion Posts: 8,079
    edited October 2014
    I picked up Vue Complete a little while back and for me, render times are not as important as the final output of the render, and I'm liking what I'm seeing with Vue. I've had carrara for years.
