Fit V3 mask to V6
n.jmurovn.jmurov Posts: 91
Hello,
I'm trying to fit a V3 full-face mask (similar to Batman's) to a V6-based character but it won't work. What would be the easiest way to fix that? can it be done from within DAZ or would I need to export it to e.g. Blender and fit it there? Should be a simple task, I guess, as basically what I need to do is to scale it and make sure that the eyes, nose and mouth openings are where they should be and perhaps slightly change the geometry. It's for a single shot with the default facial pose. Thanks.
    If you have the V3 Iconic Shape for Genesis 1, you can autofit the mask to Genesis, save it as a Support Asset, then autofit that to Genesis 2.
  • n.jmurovn.jmurov Posts: 91
    It worked, thanks.
