Carrara Help
stormqqstormqq Posts: 76
I imported an obj model exported from daz but it doesn't load the textures ,I meant my model is entirely grey.
I use victoria 6 model with custom dress. how shall I load the textures in Carrara ? I tried Collada but then again it remove the pose.
  • stormqqstormqq Posts: 76
    solved it. all I did change the TO to Carrara and WRITE SURFACE to collect maps (then paths are relative)
  • sukyLsukyL Posts: 251
    Hi gmlsx90,
    Glad you solved the problem. If you have any more issues, there is a dedicated Carrara Discussion forum here: http://www.daz3d.com/forums/categories/66/
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,845
    if you have C8.5 you can import her rigged in duf format from your library people Genesis 2 Female characters
    or use smart content if you uninstall postgre and it works, importing I find is less iffy
