Strand based hair for G8 and G8.1
quindor
Hi!
I'm trying to make a strand based body hair and looking for a possibility to make it work for G8 and G8.1 - As it should react to morphs of the base figure, a cap doesn't work for this.
When I make it on a G8 character, save it as wearable and load it on a G8.1 character, it doesn't work. There is no error message but the hair simply doesn't move with the figure. It's the same the other way (G8.1 -> G8).
I've checked the "Fit to.." settings, tried to do it on a shell and tried to rename the surfaces of the SBH to "Body" or "Torso" - unfortunatly with no success. Also, when I edit the SBH on the non native figure, the surfaces of the current figure do not update. So if I've created the SBH for G8, there is still "Torso" shown in the surface selection, even if I fitted it to G8.1 and pushed the "Update Surfaces" button.
Does someone has an idea how to make this work? I really don't want to do all the work twice with inevitably different results in the end.
Thanks for your help!
