WARNING: QColor::setRgb: RGB parameters out of range. Is this slowing the deleting of a model?
MPCreativeArts
Sorry for the long title, but I was hoping maybe someone else may have seen that warning and it would catch their attention. I'm losing my mind over here.
So, when I load an older scene (about 9 months ago), deleting anything takes an eternity (I'm talking between 20-40 minutes.) This only seems to happen when I use anything that was created a little while ago. The models are Genesis 8, no custom textures at all. I deleted everything else in the scene, leaving two models. I also deleted their respective clothing and hair leaving nothing in the scene but the two models. Deleted one, it took 28 minutes. Zeroed the model pose of the remaining model and hit delete. That took 17 minutes. I then hit undo to get that model back. Also took 17 minutes. Here is the log for this sequence starting with the warning:
2021-02-11 01:46:00.246 WARNING: QColor::setRgb: RGB parameters out of range
2021-02-11 01:46:00.511 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2021-02-11 01:46:00.526 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2021-02-11 01:46:00.526 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2021-02-11 01:46:00.595 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.02)
2021-02-11 01:46:00.600 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2021-02-11 01:46:00.848 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 2606k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 2606k triangles, 0 fiber instances yielding 0 segments) took 0.248s
2021-02-11 01:46:00.848 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2021-02-11 01:46:00.905 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 629 textures, 0 lambdas (0 unique)
2021-02-11 01:46:01.068 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2021-02-11 01:46:01.077 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2021-02-11 01:46:03.786 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2021-02-11 01:46:03.787 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2021-02-11 01:46:03.788 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2021-02-11 01:46:03.788 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2021-02-11 01:46:03.793 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2021-02-11 01:46:03.794 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2021-02-11 01:46:03.797 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2021-02-11 01:46:03.810 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2021-02-11 01:46:03.816 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 1
2021-02-11 01:46:03.825 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 2 device(s):
2021-02-11 01:46:03.825 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1080)
2021-02-11 01:46:03.825 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 1 (GeForce GTX 1080)
2021-02-11 01:46:03.825 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2021-02-11 01:46:05.147 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2021-02-11 01:46:05.151 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1080): 0 iterations, 0.005s init, 0.000s render
2021-02-11 01:46:05.151 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 1 (GeForce GTX 1080): 0 iterations, 0.010s init, 0.000s render
2021-02-11 02:18:30.825 File loaded in 0 min 0.4 sec.
2021-02-11 02:18:30.826 Loaded file: casual closet cami top.duf
2021-02-11 02:18:37.803 File loaded in 0 min 0.2 sec.
2021-02-11 02:18:37.804 Loaded file: casual closet flare pants.duf
Any ideas?
That's file loading (and it appears you are using the Iray preview), not the deletion. Figures with a lot of linked proeprties do take a while to delete, though it does appear there may be system-specific factors involved too.
