How to get rid of error message window?
Of course we all know the "Duplicate formulars found, check error log for details". As there is only an "ok" button, it's simply to inform you that there is something wrong. Still the program and installed objects work. So I don't need to know what object causes the error (as there are quite some) as I don't bother and neither want to bother you with hunting down the problem. After having checked other threads I noticed that it might be quite some work to find the malicious object.
I just want this popup not to pop up... what's the use of stopping the loading process in between, then showing the text, forcing you to hit "ok" and it continues loading. It's nothing more than a nag screen once you got the info.Every time I load a scene or create a new from scratch, always an unnecessary break.
But the installed congent is not working, at least in the case of the second property in the duplication.
Yes, that's an easy way to find out what's causing the problems and get rid of the double entry in the medium run.The nag screen is like... a physician or a bitching wife telling me to stop drinking over and over again and I just don't want to stop it cause I think I know the consequences - just an example, of course.
