Opacity for Michael 8.1 skin shader
Noah LGPNoah LGP Posts: 2,617
edited February 2021 in New Users
Hi,
Cutout parameter isn't available for the skin shader of Michael 8.1, I would like to know if there is another way to apply an alpha mask.
Post edited by Noah LGP on
  • ElliandraElliandra Posts: 642
    Hi there!
    I double checked with a few people to confirm there is no cutout opacity or transparency for the PBRSkin shader as it's meant for actual skin. If you want to apply transparency/alpha/opacity you'll need to use the Iray Uber shader system wink
    Hope this helps!
    Elli
    Post edited by Elliandra on
  • Noah LGPNoah LGP Posts: 2,617
    Then I will use LIE in order to merge the layers and apply a mask to the maps on the top.
    Geoshell can't be used with this shader when there is transparency.
