Limited menu bar and inability to
inthanityinthanity Posts: 89
Hello,
It appears that something is amiss with my program, or that I need some setting changed, as you can see in the included image I do not have all the proper menu bar options at the top left ("EDIT" is conspicuously missing), I can not save (among other things), and the keystrokes to save, undo, etc. do not work.
Any ideas?
821 x 237 - 68K
  • fixmypcmikefixmypcmike Posts: 19,730
    Are you able to change the layout using the Window menu?
  • inthanityinthanity Posts: 89
    Hello,
    Any ideas?
    821 x 237 - 68K
  • Richard HaseltineRichard Haseltine Posts: 111,701
    You should be able to go to Window>Workspace>Select Layout. Full Service (Beta) will give limited (but not that limited) menus, the other options will give the full menu set.
    Please don't make multiple posts on the same topic - it just leads to duplication of effort. Your threads on this issue have now been merged.
