Issue: what is this new pepper dust on hair render I have now?
hi, I can;t figure it out on this problem. I have some kind of pepper, black pixel, grain effect over the hair on renders (iray) since some days.
I have no idea where to start to look on how to fix it.
my spec.
i7 comet lake
16gb ram
nvidia RTX2070 8GB
M.2 1T drive
asus system
daz 4.15 pro last update 07/feb 2021.
I have no errors, render complete 100%, but when I'll pass the image on photoshop to the montage heeeeek, what is that?
engine is IRAY GPU only (no cpu). Material shine (over present) is apply first, then the colour...
hair are oot turbulent, but i noticed also on other vendors hair (for example monica hair have the identical issue), and NOT all hair, have this issue. Some render correctly in about 20-30 minutes.
I have try also on my other PC, with similar specs, (less powerful). bue result is the same... got the black points.
anyone faced the same issue?
thanks in advance
Tiziano
Hi! Same thing is happening to me! Started after I updated to 4.15 version, everything was fine on 4.14, so I guess it has something to do with the new update. Anyone knows a way to downgrade version?
You may want to have a book in these threads:
https://www.daz3d.com/forums/discussion/465896/hair-renders-with-weird-glitches-could-really-use-some-advice
https://www.daz3d.com/forums/discussion/469166/fireflies-problems
than kyou for your comments, I will follow the post you linked above. Cheers
