problem with genesis 2 figures in Poser
Hello !!!
I have a problem with genesis 2 figures in Poser, how do I get it out to the x-y-z Translate in the hip area to make it visible?
Thanks in advance.
Hello !!!
Thanks in advance.
Tt should load at zero so you should be able to see it... but if you can't for some reason, open your hierarchy tab if it's not, open up the body until you can see hip, click on it, and change the dials in parameters. So basically exactly the same as working with any other figure.. you can also move it around by just selecting body, if you need to y-rotate it works better to use body than hip usually.
Thank you for your Help !
