Installing daz3d 32 bit on windows 64 bit OS
arunparunp Posts: 5
Hi,
Because of Lip Sync functionality. I need to install 32 bit Daz. But when I go to the download page and clicks on the green button. It automatically installs the 64 bit. How do i install the 32 bit DAz.
Is there any link
-thanks and regards,
-A
  • SimonJMSimonJM Posts: 6,108
    If you're going to do it manually you should see all varieties (Windows and Mac, 32- and 64-bit) in your Product Library
    If you're doing it via DIM you'll need to change the options to include 32-bit products,
  • fixmypcmikefixmypcmike Posts: 19,739
    To change the download filters in DIM, go to the Ready To Download tab and click "Download Filters".
  • namffuaknamffuak Posts: 4,534
    Also, if installing both versions by DIM you must define both a 32-bit and 64-bit installation directory. The defaults are "C:\Program Files" for 64 bit and "C:\Program Files(X86)" for 32-bit. Under these DIM will create the sub-path "DAZ 3D\Studio4" and install (among other items) Studio4.exe - "C:\Program Files\DAZ 3D\Studio4\Studio4.exe" and "C:\Program Files(X86)\DAZ 3D\Studio4\Studio4.exe" for the defaults.
    You can use any path you want, but the 32 and 64 bit paths MUST be different. I use "D:\bits-32" and "D:\bits-64" on my system.
  • como puedo descargar el de 32 bits? :c
    If you are using Install Maanger make sure you have the Download Filters set to show 32 bit software, if you are using manual installers the 32 bit version should be on the same page as the 64 bit - at least for Windows.
